- Mobile Apps
- iOS
- Mobile web editors
- Spreadsheet Editor web version
- Align data in cells
Align data in cells
You can align your data within a cell horizontally and vertically. To do that:
- select a cell, a range of cells or the whole worksheet,
- open the Cell settings panel by
- tapping the
icon at the top toolbar, or - tapping the Cell option in the pop-up menu,
- tapping the
- tap the
icon to the right of the
Text Format section. - select one of the horizontal or vertical alignment types:
- Tap the necessary horizontal alignment type to apply it:
- tap the Align Left
menu item to line up the text by the left side of the cell (the right side remains unaligned). - tap the Align Center
menu item to line up the text by the center of the cell (the right and the left sides remains unaligned). - tap the Align Right
menu item to line up the text by the right side of the cell (the left side remains unaligned). - tap the Justified
menu item to line up the text by both the left and the right sides of the cell (additional spacing is added where necessary to keep the alignment).
- Tap the necessary vertical alignment type to apply it:
- tap the Align Top
menu item to align your data to the top of the cell; - tap the Align Middle
menu item to align your data to the middle of the cell; - tap the Align Bottom
menu item to align your data to the bottom of the cell.
- tap the Align Top
