Remove rows/columns
To delete an unnecessary row or column,
  1. select a single row/column by double-tapping its heading.
    Note: if you want to delete several rows/columns at once, expand the selection dragging the green selection handles Column selection handle.
  2. tap the Delete option in the pop-up menu that appears.
