- Apps
- Configuration
- Integration
Integration
Integration settings
The Integration section is used to enable the LDAP settings, enable the SSO settings, add plugins, integrate DocSpace with third-party services and adjust the SMTP settings. In the server version, you can also connect ONLYOFFICE Docs.
LDAP settings
When using ONLYOFFICE DocSpace, the first thing that you need to do is to create accounts for all your company employees. But if it numbers more than 50 persons, the process of creating new portal users will take a lot of time. The LDAP Settings option allows you to import the necessary users and groups from an LDAP Server (e.g. OpenLDAP Server or Microsoft Active Directory) to DocSpace, literally, in several minutes. The newly created users, in turn, don't need to memorize new passwords and logins because they will sign in to DocSpace using their credentials stored on your LDAP Server.
In the SaaS version, this is a Paid feature (available for the paid Business plan only).
Fill out the required fields and click Save.
For more detailed information on each field and corresponding values, please refer to the following instructions.
Single sign-on settings
The Single Sign-on section allows you to enable/disable third-party authentication using SAML, thereby providing users with a quicker, easier and more secure way to access the DocSpace.
Generally, the Single Sign-on technology allows users to sign in only once and then get access to multiple authorized (i.e. integrated with an Identity Provider) applications/services without having to enter their credentials each time they access a different application.
To learn more about configuring SSO, read this article.
Plugins
Add plugins to extend the functionality of DocSpace with extra features.
There are two types of plugins: system ones, which we develop ourselves, and custom ones. You can upload a custom plugin on this page if this option is enabled in the config.
In the SaaS version, there are some restrictions:
The plugin can be uploaded in the zip format and should have the following structure:
- config.json - plugin.js - assets - image1 - ... - imageN - The maximum size of the archive itself and each file is limited to 5 MB.
- The maximum number of images is 10.
- The list of image formats is limited to the following ones: .jpg, .jpeg, .png, .svg.
Currently, the following system plugins are available: draw.io, pdf-converter, speech-to-text, markdown, zip-archives, image-editor, codemirror.
In the server version, you can remove system plugins, if the configuration and settings allow it.
The incompatible versions of plugins are highlighted in red. When hovering over an outdated plugin version or uploading a new custom plugin you will be prompted to update the plugin to a compatble version.
For more details on DocSpace plugin SDK, please refer to api.onlyoffice.com.
Third-party service integration
Use Authorization keys to connect your DocSpace with third-party services: Amazon AWS S3, Apple, Box.com, DropBox, Facebook, Google Cloud Storage, LinkedIn, Nextcloud, OneDrive, Telegram, X, Rackspace Cloud Storage, WeChat, Zoom.
In the SaaS version, some services are available for the paid Business plan only (Amazon AWS S3, Google Cloud Storage, Rackspace Cloud Storage).
- Connect your Apple, FB, LinkedIn, Nextcloud, X, WeChat, Zoom account to log in to your DocSpace quickly. In the cloud version, the authorization keys parameters for these services are set up automatically. Integration with Zoom is currently available in the server version only.
- Link up your DocSpace with Box, Dropbox, OneDrive to use the connected account as a third-party resource when creating backups. In the cloud version, the authorization keys parameters for these services are set up automatically.
- Connect the Amazon AWS S3, Google Cloud Storage, Rackspace Cloud Storage or service to use the connected cloud storage as a third-party storage when creating backups.
- Connect the Telegram service to receive portal notifications via Telegram.
For more details on the third-party service integration, please refer to our instructions.
SMTP settings
The SMTP Settings subsection allows you to configure your DocSpace so that the email notifications to be sent using your own SMTP server. To do that,
- In the Host field, specify the domain name of the SMTP server you use.
- In the Port field, specify the SMTP port number. It's recommended to use port 587 or 25.
- Turn on the Authentication switcher if the SMTP server requires authentication.
- In the Host login and Host password fields, specify the login and password you use to access the SMTP server.
- Check the Auth via NTLM box to be able to login using SaslMechanismNtlm.
- In the Sender Display Name field, specify the name of the sender which will be displayed in the From: field.
- In the Sender Email Address field, specify the email address of the sender.
- Check the Enable SSL box to enable encrypted connections.
Click the Save button.
To verify whether the specified settings are correct, click the Send Test Mail button. If the settings are specified correctly, you'll receive the SMTP Test Message to the email address specified in your user profile on the portal.
Document Service settings
The Document Service subsection allows you to connect ONLYOFFICE Docs (in the server version only). To do that:
- Go to the DocSpace Settings and select the Integration -> Document Service section.
Fill in the Document Editing Service Address field. Specify the URL address where ONLYOFFICE Docs is installed. If you install ONLYOFFICE Docs on a custom port, you must specify the port, e.g.:
http://127.0. 0.1:8081/ImportantThe address of ONLYOFFICE Docs must be accessible from ONLYOFFICE DocSpace, as well as the address of ONLYOFFICE DocSpace must be accessible from ONLYOFFICE Docs. - You can check the Disable certificate verification (insecure) option to disable the certificate verification and allow DocSpace to establish connection with ONLYOFFICE Docs if you are using a self-signed certificate for your ONLYOFFICE Docs (otherwise, DocSpace will not validate a self-signed certificate and will not allow connection to/from ONLYOFFICE Docs). This is an insecure solution, and we strongly recommend that you replace the certificate with the one issued by some CA.
Fill in the Secret key field specifying the secret used to sign the data. You can leave it empty to disable this setting.
Starting from ONLYOFFICE Docs v7.2, JWT is enabled by default and the secret key is generated automatically. You need to specify the JWT parameters in the ONLYOFFICE DocSpace configuration file as well. For more details, see this article.
- Click the Show link next to the Advanced server settings section.
- Fill in the Authorization header field. You can leave it empty to use the default header.
If your network configuration does not allow requests between the installed DocSpace and ONLYOFFICE Docs using the public addresses, specify addresses for internal requests in the corresponding fields:
- Fill in the Document Service address for internal requests from the DocSpace field. Specify the address that is used to access ONLYOFFICE Docs from ONLYOFFICE DocSpace.
- Fill in the DocSpace address for internal requests from the Document Service field. Specify the address that is used to access ONLYOFFICE DocSpace from ONLYOFFICE Docs.
If your ONLYOFFICE Docs/ONLYOFFICE DocSpace installations are not switched to https, please, make sure that you specify
httpin the addresses.
- Save the settings by clicking the Save button.
For example, on the machine with the Docker version of Docs, the default path is /var/www/onlyoffice/Data/license.lic You can refer to this article to find out paths for other OS.
