You can disable or re-enable the created webhook using the switcher next to it. Use the
icon on the right to change the webhook settings specified during its creation, view the webhook history, or delete the webhook.
Click the
icon next to the certain webhook and select the
Webhook details option in the context menu.
The following details are available:
- Status – a response status.
- Event ID – an ID of the event.
- Event time – a date when the event occurred.
- Delivery time – a date when the webhook was sent to the endpoint.
In the Request/Response sections, you can also view the POST request header, POST request body, POST response header, and POST response body. Use the
icon to copy the request or response header/body to the clipboard.
Use the
icon next to the Webhook details caption to redeliver the webhook.
