Manage slides
Create new slides
To create a new slide:
tap the
on the
Slide tab, select a slide with the necessary layout.
noteNote: you can change the layout of the added slide anytime. For additional information on how to do that refer to the Change slide layout section of this guide.
A new slide will be inserted after the selected one in the list of the existing slides on the left.
Duplicate slides
To duplicate a slide:
- tap the necessary slide in the list of the existing slides on the left,
- open the slide settings panel by
- tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
- tapping the
- swipe up and tap the Duplicate Slide button.
The duplicated slide will be inserted after the selected one in the slide list.
Move slides
To move an existing slide:
- touch and hold the necessary slide in the list of the existing slides on the left,
- without lifting your finger, drag the slide to the necessary place in the list (a horizontal line indicates a new location).
Delete slides
To delete an unnecessary slide:
- tap the slide you want to delete in the list of the existing slides on the left,
- tapping the
- tapping the
- swipe up and tap the Delete Slide button.
