Change application settings
To access the Document Editor advanced settings:
  1. Tap the Tools iconTools icon in the right corner of the top toolbar.
  2. Tap the arrow next to the Application SettingsApplication Settings menu item.
Currently, the following advanced settings are available:
  • Unit of Measurement allows to specify what units are used on the rulers and in properties windows for measuring elements parameters such as width, height, spacing, margins etc. You can select the Centimeter or Point option.
  • Turn the spell checking on or off using the Spelling switcher.
To adjust spell checking by choosing a document language:
  2. Tap the arrow next to the Document LanguageDocument Language menu item.
  3. Choose the required language.
Power up your iOS
