Select background color for a paragraph
Background color is applied to the whole paragraph and completely fills all the paragraph space from the left page margin to the right page margin.
To apply a background color to a certain paragraph or change the current one:
  1. Put the cursor within the paragraph you need, or select several paragraphs or the whole text.
  2. Open the Paragraph Settings panel by
      Toolbar
    • tapping the Paragraph option in the pop-up menu.
  3. Tap the arrow next to the color field in the Background section to open the color palette window.
    Paragraph background
  4. Select one of the available colors in the Theme colors or Standard colors or create your own custom color by clicking the Create custom color button.
To clear the background color of a certain paragraph, use the No Fill No filling icon below the color palettes.
