- Apps
- Configuration
- KDrive
KDrive
Connect the KDrive service to use the connected cloud storage as a third-party resource when creating backups or public rooms.
Storing backup
To store your DocSpace data backup in KDrive,
- Go to the 'Backup' section (Settings -> Backup -> Third-party resource).
- Select KDrive as the desired storage and click the 'Connect' button.
- Fill out the Login and Password fields.
- Click the Save button.
- Click 'Create copy'.
Storing public room data
To store your public room data in KDrive,
- Go to the Rooms section on the left.
- Use the New room button in the upper left corner or the
Plus icon above the list of rooms. - Select the Public room.
- Enter the room name, add tags, upload an image.
- Turn on the Third-party storage switcher.
- Select KDrive from the list and click Connect.
- In a new window, specify your login and password, and click Save.
- A new folder for storing this room’s data will be created in the connected storage. If necessary, uncheck this option and select the already existing folder in the connected storage.
- Click Create.
For more details about creating rooms, read this article.
