- Apps
- Administration
- Managing user types
Managing user types
Managing user types and permission levels allows you to control which sections users can access and which actions they can perform in ONLYOFFICE DocSpace. Once users are added to DocSpace, admins can manage them: sort and filter the user list to easily find the necessary user, edit the user info, change user types (promote or demote users), resend invitations, disable active users, and remove disabled users from DocSpace. Admins can also manage users within a certain room.
All DocSpace user accounts are listed in the Contacts section. To open the user list, click the
icon next to your name in the lower left corner and select the Contacts option. The Members, Groups, and Guests tabs are available on the left.
When managing users in DocSpace, the available actions differ depending on the user type:
| Section\User type | Owner | DocSpace admin | Room admin | User | Guest |
| Contacts | |||||
| Inviting "DocSpace admin" | |||||
| Inviting "Room admin" | |||||
| Inviting "User" | |||||
| Inviting "Guest" | |||||
| Promoting to "DocSpace admin" | |||||
| Promoting to "Room admin" | |||||
| Promoting to "User" | |||||
| Demoting "DocSpace admin" to "Room admin" or "User" | |||||
| Demoting "Room admin" to "User" | |||||
| Demoting "User" to "Guest" | |||||
| Disabling "DocSpace admin" | |||||
| Disabling "Room admin" | |||||
| Disabling "User" | |||||
| Disabling "Guest" | |||||
| Editing or removing users | |||||
| Viewing own guest list | |||||
| Viewing someone else's guest list |
Operations in the Members and Guests lists
On the Contacts -> Members tab, admins can view, add and manage internal users.
On the Contacts -> Guests tab, room admins can view and manage their own guest list. The DocSpace owner and DocSpace admins can also view and manage someone else's guest list.
Using tools on the top toolbar, you can perform the following operations:
- Search for a user/guest name using the search bar at the top of the user/guest list.
Filter the user list by group (Without group, Other), status (Active, Pending invite, Disabled), type (DocSpace admin, Room admin, User), account (Paid, Free), account login type (SSO, LDAP, standard login) and storage quota ((if enabled) Default quota, Custom quota) using the
button. Select the necessary filter parameters and click Apply. To clear the filter, use the Clear all option if several parameters are selected or the cross icon if a single parameter is selected.
The guest list can be filtered by inviter (Me, Other), status (Active, Pending invite, Disabled), account login type (SSO, LDAP, standard login).
Sort users by name, type, group, email using the
button. Click the arrow next to the selected parameter to change the sort order.
Guests can be sorted by email, inviter, registration date.
Use the
icon to display or hide the Type, Group, Email, Storage / Quota columns in the user list (Compact view).
The Email, Inviter, Registration date columns are available in the guest list.
Using the right-click menu or the
icon next to the user/guest name, you can perform the following actions. The actions may vary depending on the account status:
Invite again (For Pending accounts only) – to send an invitation to DocSpace again.
Info – to view the user/guest info. You can also use the icon in the upper right corner of the top toolbar.
Room list – to view the rooms the user/guest is invited to (the filter by room member will be applied).
Change email (For Active accounts only) – to specify a new email address.
Change password (For Active accounts only) – to set a new password.
Reset authentication (For Active User accounts only) – to log out all active connections. This action is only available when two-factor authentication is enabled. It terminates all active sessions and resets the authenticator app configuration.
Change type (For Active and Pending Guest accounts) – to promote the Guest type to User and move the User to the Members list.
Disable (For Active and Pending accounts) – to disable the user/guest.
Enable (For Disabled accounts only) – to re-enable the disabled user/guest.
Delete user/guest (For Disabled accounts only) – to remove the disabled user/guest.
Remove – to remove the guest from the Room admin guest list. This action is available only for the Room admin in the list of their guests. It does not block or remove the guest from the portal.
Change owner (For the Owner account only) – to assign another DocSpace owner.
Using the right-click menu in the Storage / Quota column next to the user name, you can perform the following actions:
- Change quota (if the default quota is enabled) – to set a custom quota per user.
- Set to default (if the default quota is enabled and changed) – to set a custom quota to the default value.
- Disable quota (if the default quota is enabled) – to disable the quota.
Resending invitations to DocSpace
- In the Contacts section, use the Members or Guests tab on the left.
- Click the
icon next to the user name or right-click one of the pending accounts in the list. - Select the
Invite again option from the menu.
Changing user types
- Click the
icon next to the user name. - Select the
Change type option from the menu. -
Select a different user type.
Guests can be promoted to Users, Room admins, or DocSpace admins. Users can be promoted to Room admins or DocSpace admins and demoted to Guests. Admins can be demoted to Users or Guests.
When downgrading Users/Admins to Guests, the rooms are reassigned to another Admin right away. If the 'My documents' section contains shared files, they will be reassigned to the selected Admin in 30 days. The 'My documents' section will be available to the User demoted to Guest for 30 days only for viewing, downloading, and clearing the section. After this period, the 'My documents' section will no longer be available to the Guest. If the Guest decides to delete all documents, regular documents are deleted, shared ones are moved to the previously selected Admin.
Changing user/guest account statuses
- Click the
icon next to the user/guest name. - Select
Disable or
Enable.
Removing users/guests from DocSpace
To remove a disabled user/guest who did not create rooms or add documents to the room,
- Click the
icon next to the disabled user/guest name. - Select the
Delete user/guest option. - A confirmation window opens. Note that personal documents and folders in the 'My documents' section of this user will be deleted. Click Delete.
Sharing guests
Share guests with other team members by generating and sending a link.
- In the Contacts section, use the Guests tab on the left.
- Click the
icon next to the guest name. - Select the
Share guest option. The link will be copied. - Send the copied link to your team members. The link is valid for 7 days.
Your team members can open the link and approve or deny the shared guest by clicking the corresponding button. The approved guest will be added to the team member's guest list.
Reassigning data when deleting profiles
If you want to remove a disabled user/guest who created rooms or documents/folders in the room, rooms created by this user and documents stored in these rooms will be reassigned automatically to an admin performing the deletion. Reassign data manually to choose another destination user for reassignment.
What happens to the data after reassigning
After you reassign data and delete a user/guest, the related contents created by a user will be processed as follows:
- Personal documents and folders in the 'My documents' section of this user will be deleted.
- Rooms and documents/folders created by the user in a room are not deleted, but their ownership is reassigned to the selected user.
Deleting a user or guest
To delete a user or guest,
- Click the
A confirmation window opens where you'll be prompted to reassign the user's or guest's data:
- Click the Reassign data to another user link in the confirmation window.
- A new panel opens where you can select a DocSpace user you wish to reassign data to. Click the Plus icon in the New data owner section and choose the necessary active user from the list.
- The Delete profile when reassignment is finished box is checked by default that allows to automatically delete the profile after data reassignment.
Click the Reassign button.
You can use the Abort transfer option to abort data reassignment.Once the reassignment process is over, you'll be notified via email.
If you unchecked the Delete profile when reassignment is finished box, you can return to the list of disabled users and manually delete the user/guest without losing their data.
