- Docs
- Configuration
- Community
- Docker version
- Enabling debug logging in ONLYOFFICE Docs
Overview
In certain cases, it is necessary to run ONLYOFFICE Docs in debug mode — for example, to troubleshoot performance issues, inspect logs, or collect information for support.
There are two options to launch the ONLYOFFICE Docs in debug mode.
Option 1. Using the environment variable (Docker only)
If you are managing the ONLYOFFICE Docs container via Docker or Docker Compose, it is preferable to use an environment variable to enable the debug log level:
Docker
Set the environment variable with
docker run:docker run -i -t -d -p 8080:80 \ -e DS_LOG_LEVEL=DEBUG \ onlyoffice/documentserver-de:latest -
Restart the container if it is already running:
docker restart <container> -
Logs can be viewed with:
docker logs -f <container>
Docker Compose
Set the environment variable in
docker-compose.ymlwhen running the container:services: documentserver: image: onlyoffice/documentserver-de:latest container_name: documentserver restart: always environment: - DS_LOG_LEVEL=DEBUG ports: - "8080:80" -
Start Docker Compose:
docker-compose up -d -
docker-compose restart documentserver -
docker-compose logs -f documentserver
Option 2. Using the log4js configuration file
To launch the ONLYOFFICE Docs in the debug mode:
Open the log4js configuration file. The path to the file depends on the operating system you use:
- For Windows -
C:\Program Files\ONLYOFFICE\DocumentServer\config\log4js\production.json - For Linux -
/etc/onlyoffice/documentserver/log4js/production.json - For Docker -
/etc/onlyoffice/documentserver/log4js/production.json(within the Docker container)
- For Windows -
Refer to the following code block
{ "categories": { "default": { "appenders": [ "default" ], "level": "WARN" } } } - Change the
levelvalue from"WARN"to"DEBUG". - Save the changes in the
production.jsonconfiguration file. -
Apply the changes executing the following command:
Linux
systemctl restart ds-*Docker
supervisorctl restart allOr restart the ONLYOFFICE DocumentServer Proxy service for Windows:
net stop DsProxySvc net start DsProxySvc net stop DsConverterSvc net start DsConverterSvc net stop DsDocServiceSvc net start DsDocServiceSvc -
The logs are stored in the following locations (depending on the installation type):
- For Windows -
C:\Program Files\ONLYOFFICE\DocumentServer\Log - For Linux -
/var/log/onlyoffice/documentserver - For Docker -
/var/log/onlyoffice/documentserver(within the Docker container) and/app/onlyoffice/DocumentServer/logs/documentserver(on the host if you mount the volume)
- For Windows -
