The Projects app for iOS allows you to manage projects stored in your ONLYOFFICE account on your mobile device. Using this app, you can view, create and edit projects, milestones, tasks, subtasks, manage your project team, assign responsible persons, access project documents, create discussions and leave comments.
First launch
The Projects app is available on the AppStore. After you've downloaded and installed the application on your mobile device, tap the
icon to launch it.
Connecting to a portal
When you launch the Projects app for the first time, the Connection to cloud panel opens. To sign in to your portal:
- enter your existing portal address (https://portalname.onlyoffice.com) and tap the Continue button,
- enter your email address and password you use to access your account,
- tap the Sign in button.
Note: alternatively, you can specify the portal address and sign in to your portal using your Facebook or Google account, if you have previously connected one of these accounts to your profile on the portal.
To sign out from your account:
- tap the
icon in the upper left corner,
- go to your current account tapping your name on the top of the screen, then tap Logout at the bottom of the screen and confirm this action.
Creating a new portal
If you do not have an ONLYOFFICE account, you can easily create a new portal right from the mobile application when it is launched:
- tap the Create cloud link at the bottom of the Connection to cloud panel,
- fill in the registration form: create your Portal address (e.g. portalname.onlyoffice.com), enter your First name, Last name and Email address and tap the Continue button,
- enter and repeat a password, then tap the Create portal button.
The password must be at least 8 but no more than 30 characters long.
Account management
If you have several ONLYOFFICE accounts (e.g., accounts created on two different portals) you can connect them to the Projects app to quickly and easily switch between all your existing accounts and access necessary projects. If you have already signed in to an ONLYOFFICE account, perform the following actions to connect another account:
- tap the
- go to your current account tapping your name on the top of the screen, then tap Logout and confirm this action,
- on the Accounts screen tap the Select another account link and connect another account as described in the Connecting to a portal section above.
Afterwards you will be able to swipe left or right the Accounts screen to see all the connected accounts and choose the necessary one.
To sign in to a certain account that you have previously connected, select the account at the Accounts screen and tap the Continue button. You will be logged in without the necessity to enter your login and password.
To disconnect a certain account, select the account at the Accounts screen, tap the
icon in the upper right corner and confirm this action. You will be logged out from this account and it will be removed from the list (you will be able to connect it again later, if necessary).
Application sections
To quickly switch between the Projects app sections, tap the
icon in the upper left corner, then tap the necessary item from the navigation menu.
Your Projects module contains the following sections:
Projects is a section that contains all your projects;
Milestones is a section that contains all milestones related to your projects;
Tasks is a section that contains all tasks related to your projects;
Discussions is a section that contains discussions related to your projects;
Documents is a section that contains files and folders corresponding to your projects.
Application settings
You can enable a passcode protection for your application. To do that:
- tap the
- tap the Settings option at the bottom of the screen,
- tap the Passcode Lock menu item,
- tap the Turn Passcode On option,
- specify your 4-digits passcode and confirm it.
When the passcode is turned on, you will be able to change it or turn it off using the corresponding options in the Passcode Lock section.
The Settings section also contains the About section with the information about the application, the Support option that allows to contact the support team and the Introduction Tour that discovers main application features.
