Insert a table
- select the slide where you want the table to be put,
- tap the
- switch to the
tab and choose the Table menu item. Select one of the available table templates. Each template combines certain formatting parameters, such as a background color, border style, row/column banding etc.
- in the Table Size window that opens, set the necessary Columns and Rows number (the 3 by 3 cell table is selected by default, you can specify up to 10 rows/columns),
- tap OK.
The table will be added. The insertion point is placed in the upper left cell so that you can start entering data. Tap within a different cell to place the insertion point in it.
Resize and move the table
When you tap a table cell, the column width resize handles appear above the table and the row height resize handles appear to the left of it.
To change a row height, touch the corresponding
handle located to the left of the table and drag it up or down.
To change a column width, touch the corresponding
handle located above the table and drag it to the left or right.
When you tap a table cell or a table border, the resize handles
also appear on the table borders. Drag them to change the table size.
Touch and hold the table border to drag the table to another place on the current slide.
Add or delete rows or columns
- tap a cell within the necessary row/column,
- open the settings panel by
- tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
- switch to the Table tab,
- use the corresponding icons:
- to insert a column at the left side from the column where the cursor is placed.
- to insert a column at the right side from the column where the cursor is placed.
- to insert a row above the row where the cursor is placed.
- to insert a row below the row where the cursor is placed.
- to remove the column where the cursor is placed.
- to remove the row where the cursor is placed.
Adjust the table settings
- select the table by tapping on it,
- tapping the
- swipe up and tap the the necessary menu item: Style, Reorder, Align, or Cell Margins. Use the
Back arrow on the left to return to the previous settings section.
The Reorder section allows to set the selected table position as related to other objects when several objects overlap each other. To learn more, please refer to the Manipulate objects section of this guide.
The Align section allows to align the table on the slide. To learn more, please refer to the Manipulate objects section of this guide.
The Cell Margins option allows to set the space between the text within the cells and the cell border. Drag the slider to set the necessary value.
Remove the table
- tapping the
- tap the Remove Table button.
