Schließen Hilfe-Center ONLYOFFICE Mobile web editors for iOS Document Editor Document Editor vollständige Dokumentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors ONLYOFFICE Mobile web editors for iOS Overview Manage files Open or create new files and folders Share files and folders Document Editor Grundfunktionen Navigate through your document Select, cut, copy, paste text Undo/redo your actions Seitenparameter festlegen Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Absatzformatierung Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Textformatierung Set font type, size, and color Apply font decoration styles Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Werkzeuge und Einstellungen Collaborative document editing Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document View document information Spreadsheet Editor Grundfunktionen Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operationen mit Tabellenblätter Create or delete sheets Manage existing sheets Zellformatierung Set font type, size, and color Add hyperlinks Bearbeiten von Zelleigenschaften Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Bearbeiten von Zeilen und Spalten Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Objekte bearbeiten Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Werkzeuge und Einstellungen Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Change app settings Macros settings Download and print your spreadsheet View spreadsheet information Presentation Editor Grundfunktionen Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Folien bearbeiten Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Textformatierung Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Change text indents Set paragraph line spacing Create lists Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Werkzeuge und Einstellungen Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation View presentation information ONLYOFFICE Mobile web editors for Android Glossar Video Häufig gestellte Fragen Allgemeines Technologie Preise Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Spaltenumbrüche einfügen Formatierung der Seite Kopf- und Fußzeilen einfügen Seitenzahlen einfügen Abschnittsumbrüche einfügen Seitenumbrüche einfügen Seitenparameter festlegen Formatierungszeichen ein-/ausblenden Lesezeichen hinzufügen Wasserzeichen hinzufügen More articles Datum und Uhrzeit einfügen Seitenparameter einstellen Seitenumbrüche einfügen Abschnittsumbrüche einfügen Seitenzahl einfügen Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Adding page numbers in word Spaltenumbruch Seitenparameter festlegen Formatierungszeichen ein-/ausblenden Insert column breaks Insert column breaks Insert column breaks Wenn Sie ein Dokument mit einem mehrspaltigen Layout bearbeiten, können Sie angeben, wo eine neue Spalte beginnen soll. Um einen Spaltenumbruch an der aktuellen Cursorposition einzufügen, tippen Sie auf das Symbol in der oberen Symbolleiste, um das Einfügefeld für neue Objekte zu öffnen, öffnen Sie die Registerkarte , wählen Sie die Option Umbruch aus, wählen Sie die Option Spaltenumbruch aus. Um den hinzugefügten Spaltenumbruch zu entfernen, positionieren Sie den Cursor am Anfang des darauf folgenden Textes und tippen Sie auf die Schaltfläche auf der Bildschirmtastatur. Power up your iOS Create, edit and view documents, spreadsheets and presentations of all popular formats Wer sich dafür interessiert hat, hat auch das Folgende gelesen: Schließen
