Articles with the tag:
Close
Close
Try in the cloud
Connecting Nextcloud to ONLYOFFICE DocSpace
Connect the Nextcloud service to use the connected cloud storage as a third-party resource when creating backups.
To store your DocSpace data backup in Nextcloud,
  1. Go to the 'Backup' section (DocSpace Settings -> Backup -> Third-party resource).
  2. Select Nextcloud as the desired storage and click the 'Connect' button.
  3. Enter the Connection url.
    For example, the URL that allows to access your Nextcloud files via WebDAV looks like this: https://yourdomain.com/remote.php/webdav/. This URL address can be found in the following way: sign in to your Nextcloud account, click the Settings icon in the lower left corner and copy the entire URL from the WebDAV field. Then switch to ONLYOFFICE DocSpace and paste the entire copied URL address, including the protocol, into the Connection URL field.
  4. Fill out the Login and Password fields.
  5. Click the Save button.
  6. Click 'Create copy'.
You Might Also Like This:
Close
