Calling your customers directly from CRM
Introduction
In the CRM module, you can not only maintain your customer base, but also manage client interactions effectively. The VoIP feature allows you to receive incoming calls from your customers and make outgoing calls directly from a web browser using virtual numbers provided by the Twilio service. Incoming calls from new phone numbers that are not stored in your customer base are automatically saved as new CRM contacts. The information about phone conversations with customers is automatically added to the communication history of your CRM contacts. You can also use an incoming call queue, record calls, receive voicemail messages, and set up your own waiting ringtones.
This guide will show you how to add and manage virtual numbers and call your customers right from the CRM module.
Step 1. Connect your Twilio account
To use the IP telephony functionality, you need to sign up for a Twilio account and connect it to your portal by specifying API credentials: Account SID and Auth token. They can be found on the Twilio Console page in the Account Summary section.
The ability to connect a Twilio account is available for portal administrators only.
Click the Settings Icon icon at the top of the page to acccess your portal settings, then open the Integration > Third-Party Services section. Click the switcher next to the Twilio service, enter the API credentials in the designated fields, and click the Enable button.
How to call your customers directly from your CRM? Step 1 How to call your customers directly from your CRM? Step 1
Once your Twilio account is connected to the portal, you can add and manage virtual numbers.
Step 2. Add a virtual number
The ability to add and set up virtual numbers is available for portal and CRM module administrators only.
To add a virtual number,
  1. In the CRM module, go to the Settings section on the left-side panel and click the VoIP Settings option.
  2. Click the Buy phone number link.
  3. In the Number purchase window, select the required number from the list of the available numbers and click Buy phone number.
    If you already have some phone numbers purchased earlier in your Twilio account, you can use the Link purchased number option: in a new window that opens, select an available Twilio virtual number and click Link purchased number.
How to call your customers directly from your CRM? Step 2 How to call your customers directly from your CRM? Step 2
When the first number is added to your CRM module, you can use Buy phone number or Link purchased number above the Virtual numbers and operators list to add other numbers.
If you are using a trial Twilio account, you cannot add more than one virtual number. Trial Twilio accounts are subject to additional restrictions. To access the full capabilities of the service, upgrade your Twilio account.
Step 3. Set up the added virtual number
To set up the added virtual number,
  1. In the Virtual numbers and operators list, select the number you want to set up.
  2. Click the Outgoing calls toggle to enable the ability to make outgoing calls in addition to receiving incoming calls using this number.
  3. Click the Call recording toggle to enable recording of all incoming and outgoing calls for this number, allowing you to play back recordings at a later time.
  4. Click the Arrow Icon arrow to the left of the necessary number to Add operators who should be able to use this virtual number. Select the required portal users from the list and click Save. Once operators are added, the VoIP VoIP Icon icon will be available to them at the top of the page.
    You can also set up Outgoing calls and Call recording for each of the added operators separately using the switchers next to the operator's name. To remove an added operator from the virtual number operator list, click the Actions Actions Icon icon to the right of the operator's name and select the Delete option.
Use the Actions Actions Icon icon to the right of the necessary virtual number to Edit or Delete the number.
How to call your customers directly from your CRM? Step 3 How to call your customers directly from your CRM? Step 3
When you select the Edit option, the Number setup page opens that allows you to change some other parameters in addition to those mentioned above:
  • You can specify an Alias for this number that makes it easier to find the number in the list.
  • In the Quick setup section, you can enable or disable Outgoing calls and Call recording (these settings are the same as the ones available in the Virtual numbers and operators list). Moreover, you can specify Working hours when the number is available for clients. Click the switcher and set the necessary time in the hh.mm format.
  • In the Ringtone setup section, you can playback the default ringtones:
    • Greeting ringtones - the greeting that callers hear when they call this phone number.
    • Queue ringtones - music on hold that callers hear when they are placed in the waiting queue,
    • Voice mail ringtones - a message that callers hear when the queue length or maximum waiting time is exceeded, at which point they may leave a voicemail message.
    If you have previously added some other ringtones in the VoIP Settings -> Common section, you can select another available ringtone for each category. It is also possible to upload custom ringtones for this virtual number directly from this page by clicking the Upload Upload ringtone Icon icon next to the ringtone you want to change.
Click the Update settings button to apply the changes you made. On this page, you can also manage the operator list for this virtual phone number.
Step 4. Adjust common settings for all numbers
Go to the VoIP Settings -> Common section on the left-side panel.
General settings section allows you to set the following parameters:
  • Incoming call queue length - this option allows you to set the maximum number of incoming calls that can be assigned to available operators simultaneously. If the number of incoming calls exceeds the specified value, the calls will be redirected to the voice mail service. Choose the necessary quantity from the list: 5, 10, 15
  • Waiting timeout - this option allows you to set the duration for which a customer will wait for an operator to respond. When this time is exceeded, the call will be redirected to the voice mail service. Choose the necessary option from the list: 5, 10, 15 minutes.
  • Operator pause - this option gives the operator time before accepting further calls — for example, to take notes on the previous conversation. This can be used to take some notes on the previous call, etc. Choose the Enabled or Disabled option from the list.
How to call your customers directly from your CRM? Step 4 How to call your customers directly from your CRM? Step 4
In the Ringtone Setup section, default ringtones are provided for all added virtual numbers. To display all the available ringtones in each category, click the Arrow Icon arrow on the left.
You can upload your own ringtones in the .mp3 format for each category. To do that, click the Actions Actions Icon icon to the right of the necessary category and select the Add ringtone option.
Once your own ringtones are added, you can go to the VoIP Settings -> Numbers page and set up individual ringtones for each virtual number separately. To remove a ringtone, click the Actions Actions Icon icon to the right of the audio record you don't need and select the Delete ringtone option.
Step 5. Receive and make calls
To start accepting and making calls,
  1. Click the VoIP VoIP Icon icon on the top of the page. The VoIP client opens in a new window.
  2. Select Online from the status list next to your name.
How to call your customers directly from your CRM? Step 5 How to call your customers directly from your CRM? Step 5
The Browser option is selected by default and is currently the only available option; no further action is required. Now you are ready to accept incoming calls.
If you receive an incoming call, you can Answer or Reject it using the corresponding buttons within the VoIP window.
If a person whose phone number is stored in your CRM customer base calls you, the contact name is displayed in this window. You can click it to open the customer profile in a new browser tab and easily find all the necessary information about the client that can be useful during the phone conversation.
To end the call, click the Disconnect button.
The Missed Calls button button in the VoIP window allows to view the list of missed calls during the current session. If you want to call back to the person who called you, hover over the missed call Missed Call icon icon in the list until it changes to the Call Back button icon, then click it.
The operators who have been granted sufficient permissions can make outgoing calls. To make a call,
  1. Click the Dial pad Icon button to open the dial pad.
  2. Click the Select contact Icon icon to open the list of all existing CRM contacts. To search for a contact, enter the full or partial contact name in the search field above the contact list. Select the necessary CRM contact from the list.
    Alternatively, you can right-click the necessary contact in the complete list of Companies/Persons on the Contacts tab and choose the Make a VoIP call option in the context menu. Currently, a contact cannot be called directly from their profile page.
    The selected contact phone number will be displayed in the corresponding field.
    Phone number
    If the contact profile contains several phone numbers (mobile, work, home), click the Arrow arrow in the right part of the phone number field to choose the necessary number. To remove the number, click the Remove number icon.
    To call the number that is not stored in your customer base, select the country code from the Country Code list and enter the phone number using the keypad or your PC keyboard.
  3. Click the Call button.
If you call a contact stored in the CRM module, the link to the contact profile is displayed in this window, so that you can open the profile in a new browser tab.
Step 6. View call list
All the calls are displayed in the Calls section. Click the Calls link on the left-side panel to open the call list. It provides the following information about calls: date and time, agent (operator name), client (customer name stored in the CRM base), call duration, and cost.
The calls can be easily distinguished by type:
  • Answered calls Icon - answered
  • Missed calls Icon - missed
  • Outgoing calls Icon - outgoing
If a call has been recorded, click the Playback Icon icon to playback the recording.
When someone leaves a voicemail message, the link to the voicemail recording stored in your Twilio account appears in the Calls section. You can listen to the voicemail message right from the Calls page or go to your Twilio account to check all the voicemail recordings.
How to call your customers directly from your CRM? Step 6 How to call your customers directly from your CRM? Step 6
To easily find a necessary call, you can use the filter field on the top and filter calls by type, caller (operator name), or date.
Calls can be sorted by date, duration, and cost by selecting the necessary parameter from the list to the right. Click the Sort Icon icon to change the sorting order.
Step 7. Add information about calls to the customer base
If you make a call to a new number that is not stored in the CRM contacts or if you receive a call from such a number, this number will be automatically saved to your CRM contacts as a new contact.
The phone number and the call date and time are used as the contact's first and last name. This phone number is also saved to the contact information. The operator who received or made the call is automatically assigned as the contact manager.
You can edit the automatically saved contact by specifying the necessary data or merging it with an already existing contact. Go to the contact profile, click the Actions Actions Icon icon to the right of the contact name, and select Edit person to update the contact details, or select This is a duplicate to merge it with an existing contact.
How to call your customers directly from your CRM? Step 7 How to call your customers directly from your CRM? Step 7
An Outgoing or Incoming call event is automatically added to the contact history, including the call duration and operator's name.
You can also add your notes about the call to the contact history manually. Select an event type from the list, set its date, add a description, and click the Add This Event button.
Watch video
How to call your customers right from ONLYOFFICE CRM using Twilio
Connect your ONLYOFFICE to Twilio to make and receive calls from your customers right from a browser. Record calls, save the information to the communication history of your CRM contacts. Use incoming call queue, receive voicemail messages, set up your own waiting ringtones, and more.
