- Mobile Apps
- iOS
- Mobile web editors
- Spreadsheet Editor web version
- Wrap text in a cell
Wrap text in a cell
Fit your data to the column width using the Wrap Text option.
- select a cell, a range of cells or the whole worksheet,
- open the Cell settings panel by
- tapping the
icon at the top toolbar, or - tapping the Cell option in the pop-up menu,
- tapping the
- tap the
icon to the right of the
Text Format section. - swipe up to see the
Wrap Text switcher and turn it on.
Note: if you change the column width, data wrapping adjusts automatically.
You can also select a cell/cell range and tap the Wrap option from the pop-up menu that appears. When data wrapping is enabled, the Unwrap option becomes available in the pop-up menu.
