Resize rows/columns
Change column width
To change the width of a single column, select the column. The Column width handle handle appears at the right border of the column heading. Tap and drag the handle to the left or to the right.
Change row height
To change the height of a single row, select the row. The Row height handle handle appears at the bottom border of the row heading. Tap and drag the handle up or down.
Power up your iOS
