Creating lists
Create lists
To create a list in your document:
  1. Place the cursor to the position where a list will be started (this can be a new line or the already entered text).
  2. Select the list type using one of the following methods:
    • Tap the List icon icon at the bottom toolbar, then tap the Bulleted list icon Bullets icon to create an Unordered list or tap the Numbered list icon Numbers icon tab to create an Ordered list.
    • Tap the Edit object icon at the top toolbar, go to the Text tab and swipe down to the list options.
      Text Settings - Lists
      Tap Bulleted list icon Bullets to create an unordered list or Numbered list icon Numbers to create an ordered list. Use the available options to customize how your bullets or numbers look.
  3. Now each time you press the Enter key at the end of the line a new ordered or unordered list item will appear. To stop that, tap the Backspace key key and continue with the common text paragraph.
You can also change the text indentation in the lists using the Decrease Indent Decrease Indent icon and Increase Indent Increase Indent icon icons at the bottom toolbar.
