Version history
View version history
To view the version history of the spreadsheet you collaborate on,
- tap the
Tools icon in the right corner of the top toolbar, - tap the
Version history menu item, - the Version history section opens:
You'll see the list of the versions, displaying its authors and creation date and time.
To know exactly which changes have been made in each separate version, tap it, and the changes will be marked with the same color next to the author's name,
- close the shape settings panel by tapping the
arrow on the right.
To open the Version history section, tap the
icon in the upper right corner.
Restore version
If you need to roll back to one of the previous versions of the spreadsheet,
- tap the necessary spreadsheet version,
- tap the Restore button below.
Tap the Close History in the upper left corner to exit the Version view mode.
