Wrap text in a cell
Fit your data to the column width using the Wrap Text option.
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the More option in the pop-up menu and choosing the Cell menu item,
  3. swipe up to see more options and tap the Text Format option.
  4. swipe up to see the Wrap Text switcher and turn it on.
  5. close the cell settings panel by tapping the Close settings panel arrow on the right.
Note: if you change the column width, data wrapping adjusts automatically.
You can also select a cell/cell range, tap the More option from the pop-up menu that appears and then select the Wrap menu item. When data wrapping is enabled, the Unwrap option becomes available in this menu.
