- Mobile Apps
- Android
- Mobile web editors
- Spreadsheet Editor web version
- Change text orientation
To change text orientation,
- select a cell, a range of cells or the whole worksheet,
- open the Cell settings panel by
- tapping the
icon at the top toolbar, or - tapping the Cell option in the pop-up menu,
- tapping the
- tap the
arrow to the right of the
Text Orientation section to open the text orientation menu. - choose the option that fits the text most:
- Tap the necessary horizontal alignment type to apply it:
Angle Counterclockwise will orientate the text at an angle and upwards,
Angle Clockwise will orientate the text at an angle and downwards,
Vertical Text will orientate the text with each character taking up one line,
Rotate Text Up will orientate the text with each character’s top point facing left,
Rotate Text Down will orientate the text with each character’s top point facing right.
- To reverse all orientation changes, repeat steps 1-3 and choose option
Horizontal Text.
