Add cell borders
To add and format borders to a worksheet,
- select a cell, a range of cells or the whole worksheet,
- open the Cell settings panel by
- tapping the
icon at the top toolbar, or - tapping the More option in the pop-up menu and choosing the Cell menu item,
- tapping the
- swipe up to see more options and tap the Border Style option to open the border parameters panel:
- swipe up to see all the available parameters and specify the border style you wish to apply:
- tap the Color option and select the necessary border color from the Theme Colors or Standard Colors palette. Return to the previous screen using the
arrow on the left. - tap the Size option and select the necessary border width: Thin, Medium or Thick. Return to the previous screen using the
arrow on the left. - select one of the available border templates:
No Border,
All Borders,
Bottom Border,
Top Border,
Left Border,
Right Border,
Inside Borders,
Inside Vertical Borders,
Inside Horizontal Borders,
Diagonal Up Border,
Diagonal Down Border.
- close the cell settings panel by tapping the
arrow on the right.
