- Mobile Apps
- Android
- Mobile web editors
- Presentation Editor web version
- Change application settings
To access the application settings,
- tap the
Tools icon in the right corner of the top toolbar, - tap the arrow next to the
Application Settings menu item.
Currently, the following advanced settings are available:
- Unit of Measurement allows to specify what units are used in properties windows for measuring elements parameters such as width, height, spacing, margins etc. You can select the Centimeter, Point, or Inch option.
- Spell Checking allows to enable or disable the spell checking function.
- Dark theme allows to switch to dark interface mode. The dark theme colors vary from black to light-gray providing a comfortable interface for working at low-light conditions.
- Macros Settings allows to choose if you want to enable all macros with or without a notification or disable all macros.
