ONLYOFFICE turns 16!
Celebrate our story with a 16-article blog series.
Menu
Docs
DocSpace
AI
Desktop Apps
Mobile Apps
Connectors
Workspace
Glossary
Video
FAQ
Home
Mobile Apps
Android
Mobile web editors
Presentation Editor web version
Set slide parameters
page size
You can change a slide size for all the slides in the presentation. To do that:
tap the
Settings
icon in the right corner of the top toolbar,
select the
Presentation Settings
menu item,
tap one of the following options:
Standard (4:3)
or
Widescreen (16:9)
use the
arrow on the left to return to the previous screen and close the settings panel by tapping the
Done
caption on the right.
Article with the
tag:
