Insert images
Add an image
  1. select the slide where you want the image to be put,
  3. switch to the Other tab Other tab and tap the Image icon Image option,
  4. select one of the following options to load the image:
    • the Picture from Library Picture from Library option will open the Media Library where you can select the necessary file.
      Note: you must have appropriate permissions on your device Media Library.
    • the Picture from URL Picture from URL option will open the Link Settings panel where you can enter the necessary image web address in the Image URL field and tap the INSERT IMAGE button.
The image will be added. Now you can change its properties and position.
Adjust the image settings
  1. select the image by tapping it,
  2. open the settings panel by
  3. tap the necessary menu item: Replace Image, Arrange, or Align. Use the Return arrow on the left to return to the previous settings section.
    The Replace Image section allows to replace the current image loading another one from the Media Library or URL.
    The Arrange section allows to set the selected image position as related to other objects when several objects overlap each other. To learn more, please refer to the Manipulate objects section of this guide.
    The Align section allows to align the image on the slide. To learn more, please refer to the Manipulate objects section of this guide.
    The ACTUAL SIZE button allows to restore the original image size.
  4. close the image settings panel by tapping the Close settings panel arrow on the right.
Adjust the shape settings
When the image is selected, the shape settings panel is also available so that you can change the shape of the image as well as adjust its border size and color, if necessary.
  3. switch to the SHAPE tab, tap the Style option, and select the Border section. Change the border Size by dragging the slider and select the necessary border Color.
    Border settings
    Tap the Change Shape section to replace the rectangular shape with another one selected from the menu. The shape of the image will change correspondingly.
    Reshape image
  4. close the shape settings panel by tapping the Close settings panel arrow on the right.
Remove the image
Select the image by tapping on it and proceed in one of the following ways:
  • tap the Delete option in the pop-up menu, or
  • open the image settings panel by tapping the Edit object icon at the top toolbar. Use the DELETE IMAGE button at the IMAGE tab.
