Version history
View version history
To view the version history of the document you collaborate on,
  • tap the Tools icon Tools icon in the right corner of the top toolbar,
  • tap the Version history icon Version history menu item,
  • the Version history section opens:
    Version history
    You'll see the list of the versions, displaying its authors and creation date and time.
    To know exactly which changes have been made in each separate version, tap it, and the changes will be marked with the same color next to the author's name,
  • close the shape settings panel by tapping the Close settings panel arrow on the right.
To open the Version history section, tap the Close settings panel icon in the upper right corner.
Restore version
If you need to roll back to one of the previous versions of the document,
  • tap the necessary document version,
  • tap the Restore button below.
    Restore version
Tap the Close History in the upper left corner to exit the Version view mode.
