- Mobile Apps
- Android
- Mobile web editors
- Document Editor web version
- Adding hyperlinks
Adding hyperlinks
Add a hyperlink
- place the cursor where you want the link to be added, or select the text passage that will get clickable,
choose the More option in the pop-up menu and tap the Add Link menu item, or do the following:
- tap the
- switch to the
Other tab, -
select the
Link option,
- tap the
after that, the Link Settings screen will appear where you can specify the hyperlink parameters:
- Link - enter a URL in the format http://www.example.com.
Display - enter a text that will get clickable and lead to the web address specified in the upper field.
Note: if you've selected a text passage before tapping the
icon, the Display field will be filled with the selected text fragment. - Screen Tip - enter a text that will become visible in a small pop-up window that provides a brief note or label pertaining to the hyperlink being pointed to.
- save the changes by tapping the
button in the upper right, and close the link settings panel by tapping the
button.
Note: to follow the added link, double-tap it, choose the More option in the pop-up menu and tap the Open Link option.
Edit or remove the added hyperlink
- open the Link Settings panel:
tap the
icon at the top toolbar, switch to the
Other tab, and select the
Link option, or
- double-tap the link, choose the More option in the pop-up menu and tap the Edit Link option,
tap the
- edit your data or use the DELETE LINK button to delete the added hyperlink,
button.
