Creating lists
To create a list in your document,
- place the cursor to the position where a list will be started (this can be a new line or the already entered text),
open the text and paragraph settings panel by
tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
tapping the
- on the TEXT tab, swipe up to see all the settings,
- tap the Bullets & Numbers option and select the necessary list type:
the first tab contains Numbers list types to create an Ordered list with digits or letters:
the second tab contains Bullets list types to create an Unordered list with markers:
the third tab contains Multilevel list types to create a Multilevel list with digits and markers:
- close the text settings panel by tapping the
arrow on the right, or use the
icon on the left to return to the previous settings section. -
now each time you press the
Enter key at the end of the line, a new ordered or unordered list item will appear. To stop that, tap the
key and continue with the common text paragraph.
You can also change the text indentation in the lists using the Decrease Indent
and Increase Indent
icons on the TEXT tab.
