Aligning your text in a paragraph
  1. place the cursor within the paragraph you need, or select several paragraphs you want the alignment to be applied to,
  2. open the text and paragraph settings panel by
  3. on the TEXT tab, swipe up to see all the settings,
  4. select the alignment type you would like to apply:
    • tap the Align Left Align Left icon icon to line up the text by the left side of the page (the right side remains unaligned).
    • tap the Align Center Align Center icon icon to line up the text by the center of the page (the right and the left sides remains unaligned).
    • tap the Align Right Align Right icon icon to line up the text by the right side of the page (the left side remains unaligned).
    • tap the Justify Justify icon icon to line up the text by both the left and the right sides of the page (additional spacing is added where necessary to keep the alignment).
    Paragraph Alignment settings
  5. close the text settings panel by tapping the Close settings panel arrow on the right.
