- Mobile Apps
- Android
- Mobile web editors
- Document Editor web version
- Inserting column breaks
When editing a document that has a multi-column layout, you can specify where a new column should start.
To insert a column break at the current cursor position,
- tap the
icon at the top toolbar to open the new object insertion panel, - switch to the
Other tab, - select the
Break option, - choose the
Column Break option.
To remove the added column break, place the cursor at the beginning of the text that followed it and press the
key on the on-screen keyboard.
