Navigate through your document
To scroll your multipage document, swipe up/down. If the document is zoomed in, you can swipe right/left. Vertical and horizontal scroll bars also appear when you begin scrolling.
To zoom in the document, use the stretch gesture: place two fingers on the screen and move them apart.
To zoom out the document, use the pinch gesture: place two fingers on the screen and move them together.
You can also navigate through the document headings. Tap the Settings icon Settings icon in the upper right corner, then use the Navigation option. Select the necessary heading in the list to jump to it.
Navigation
To switch between the Mobile view and Standard view,
  • in the View mode, tap the Standard view icon icon in the upper right corner to switch to the Standard view. To return to the Mobile view, tap the Mobile view icon icon in the upper right corner.
  • in the Editing mode, tap the Settings icon Settings icon in the top right corner and enable the Mobile View icon Mobile View switcher. Now the document corresponds to the width of your screen. Turn the switcher off to return to the Standard view.
