Protect spreadsheets with a password
To protect your spreadsheets in the Spreadsheet Editor:
  1. Tap the Settings icon Settings icon in the right corner of the top toolbar.
  2. Tap the Protection icon Protection menu option.
  3. Enable the Set password switcher. Enter the required password and verify it.
    Set password
    Please note that the password cannot be restored. Please keep it in a safe place so as not to forget it.
  4. Apply the changes by tapping the Accept button in the upper right corner, close the settings panel, and save the spreadsheet.
Next time you open this spreadsheet you will need to enter the password.
Open protected file
To change or delete the password in the Spreadsheet Editor:
  3. Disable the Set password switcher to delete the password.
  4. Enter and verify the new password to change it.
  5. Apply the changes by tapping the Accept button in the upper right corner, close the settings panel, and save the spreadsheet.
