- Mobile Apps
- Android
- Documents
- Spreadsheet Editor
- Change spreadsheet settings
You can change layout settings for the spreadsheet, i.e. the page orientation, size, margins, as well as specify which interface elements you want to be hidden or shown.
To access the current spreadsheet settings,
- tap the
Settings icon in the right corner of the top toolbar, - tap the arrow next to the
Spreadsheet settings menu item.
Currently, the following spreadsheet settings are available:
- Grid - this switcher is turned on by default. It allows to hide or show again the lines that appear around the cells.
- Headings - this switcher is turned on by default. It allows to hide or show again the column heading at the top and row heading at the left of the worksheet.
- Color schemes - is used to select the necessary Color scheme. It allows to change the default color palette for worksheet elements (font, background, autoshapes and charts).
