Add or remove rows/columns
You can insert an entire row above the selected one or a column to the left of the selected column.
Insert rows and columns
To insert an entire row:
  1. select the whole row above which you wish to insert a new one by tapping its heading,
    Note: to insert multiple rows, select the same number of rows as you wish to insert.
  2. tap the Insert above option from the pop-up menu that appears,
The program will shift the selected row down to insert a blank one.
To insert an entire column:
  1. select the whole column to the left of which you wish to insert a new one by tapping its heading,
    Note: to insert multiple columns, select the same number of columns as you wish to insert.
  2. tap the Insert left option from the pop-up menu that appears,
The program will shift the selected column to the right to insert a blank one.
Delete rows and columns
To delete an unnecessary row or column,
  1. select a single row/column by tapping its heading,
    If you want to delete several rows/columns at once, expand the selection dragging the green selection handles Column selection handle.
  2. tap the Local delete icon Delete option in the pop-up menu that appears.
