Navigate through your spreadsheet
To navigate between sheets, use the sheet navigation panel below the current worksheet. Tap the necessary sheet tab to switch to the sheet.
Sheet navigation panel
To navigate between sheets, tap the Navigation panel icon on the bottom toolbar to open the navigation panel and choose the necessary sheet. Tap the Sheet navigation icon to open a list of sheets and select the one you want to open.
To navigate between cells, use the Next cell Next cell and Previous cell Previous cell buttons located on the bottom toolbar.
Navigate sheets
To scroll a sheet, swipe up or down, left or right.
To zoom in a sheet, use the stretch gesture: place two fingers on the screen and move them apart.
To zoom out a sheet, use the pinch gesture: place two fingers on the screen and move them together.
To exit the editor, tap the Exit editor icon in the upper left corner.
