- Mobile Apps
- Android
- Documents
- Document Editor
- Change document settings
To access the Document advanced settings,
- tap the
Tools icon in the right corner of the top toolbar, - tap the arrow next to the
Document Settings menu item.
Currently, the following advanced settings are available:
- Document language is used to enable or disable the spell checking function. This option also affects spell-checking operations.
- Show non-printing symbols is used to display or hide nonprinting characters in the document text.
- Color schemes is used to select the necessary Color scheme of the document. It allows you to change the default color palette for document elements (font, background, autoshapes and charts).
