- ISO.CEILING function
The ISO.CEILING function is one of the math and trigonometry functions. It is used to return a number that is rounded up to the nearest integer or to the nearest multiple of significance. The number is always rounded up regardless of its sing.
Syntax
ISO.CEILING(number, [significance])
The ISO.CEILING function has the following arguments:
| number | The number you wish to round up. |
| significance | The multiple of significance you wish to round up to. It is an optional parameter. If it is omitted, the default value of 1 is used. If it is set to zero, the function returns 0. |
Notes
How to apply the ISO.CEILING function.
Examples
The figure below displays the result returned by the ISO.CEILING function.
