Twitter
Connect the Twitter service to log in to your space quickly.
Creating authorization keys
In the cloud version, the authorization keys parameters for Twitter are set up automatically.
In the server version, you will have to setup authorization keys for Twitter. Follow these steps:
To successfully connect Twitter to your portal, Elevated Level API is required. You can obtain it via a separate request to Twitter.
  1. Go to Twitter Developers Portal.
  2. Sign in to your account.
  3. In the left menu, go to Projects & Apps: Overview and click the + Create App button.
  4. In the App name field, enter your application name and click Next.
  5. In the Keys & Tokens section, copy API Key, API Key Secret, Bearer Token.
  6. Click App settings.
  7. Click Set up in the User authentication settings section.
  8. In the App permissions block, select "Read and write and Direct message".
  9. In the Type of App block, select "Web App, Automated App or Bot".
  10. In the App info block, specify https://service.onlyoffice.com/oauth2.aspx in the Callback URI / Redirect URL line. In the Website URL line, specify URL of the website where Twitter is connected.
  11. Click Save.
  12. Save Client ID and Client Secret, click Done.
Connecting Twitter to ONLYOFFICE DocSpace
  1. In the server version, click the Options icon menu in the lower left corner and select the Settings option.
  3. In the Third-party services section, click the sliding button to the right of the Twitter logo.
  4. Enter your keys and click the Connect button.
Signing in
To sign in via Twitter,
  1. Go to your 'Profile' page clicking the link with your name in the lower left corner of the page.
  2. On your 'Profile' page, find the 'Сonnect your social networks' caption, choose the Twitter service and click the 'Connect' button.
  3. In the opened window, grant the access to ONLYOFFICE application and enter the account credentials, if it's necessary.
Host ONLYOFFICE DocSpace on your own server or use it in the cloud
