- Mobile Apps
- iOS
- Mobile web editors
- Document Editor web version
- Select background color for a paragraph
Background color is applied to the whole paragraph and completely fills all the paragraph space from the left page margin to the right page margin.
To apply a background color to a certain paragraph or change the current one,
- put the cursor within the paragraph you need, or select several paragraphs or the whole text,
- open the text and paragraph settings panel by
- tapping the
icon at the top toolbar, or - tapping the Edit option in the pop-up menu,
- tapping the
- switch to the Paragraph tab,
- tap the arrow next to the color field in the Background section to open the color palette window,
- select one of the available colors on the Theme Colors or Standard Colors palette, or create your own Custom Color.
- go to the Add Custom Color menu,
- using the color palette, choose the necessary color and select its hue level,
- click the
button to apply the color to the selected text.
To clear the background color of a certain paragraph, use the
No Fill icon on the Standard Colors palette.
