- Mobile Apps
- iOS
- Mobile web editors
- Document Editor web version
- Insert autoshapes
Insert autoshapes
Insert an autoshape
- place the cursor where you want the shape to be put,
- tap the
icon at the top toolbar to open the new object insertion panel, - tap the
Shape tab, - select one of the available autoshapes.
The selected autoshape will be added. Now you can change its properties and position.
Adjust the shape settings
- select the shape by tapping its border (the rectangular box around the shape should be displayed as a solid line),
- open the shape settings panel by
- tapping the
icon at the top toolbar, or - tapping the Edit option in the pop-up menu,
- tapping the
- tap the necessary menu item: Style, Wrap, Replace or Reorder. Use the
Back arrow on the left to return to the previous settings section.
- Fill - to fill the inner space of the autoshape with a solid color. Swipe up to see all the palettes and tap the necessary color on the Theme Colors or Standard Colors palette or create your own Custom Color. If you don't want to use any fill, tap the
icon on the Standard Colors palette.
- go to the Add Custom Color menu,
- using the color palette, choose the necessary color and select its hue level,
- tap the
button to apply the color to the selected autoshape.
- Border - to set the border Size by dragging the slider and select the border Color on the palette,
- Effects - to set the Opacity level by dragging the slider. The default value is 100%. It corresponds to the full opacity. The 0% value corresponds to the full transparency.
The Wrap section allows selecting a text wrapping style from the available ones and adjust some additional positioning options. To learn more, please refer to the Change text wrapping section of this guide.
The Replace section allows replacing the current autoshape with another one selected from the menu.
The Reorder section allows setting the selected autoshape position as related to other objects when several objects overlap each other. To learn more, please refer to the Manipulate objects section of this guide.
Add text within the autoshape
- place the insertion point by tapping inside the autoshape (the rectangular box around the shape should be displayed as a dashed line),
- start typing your text using the on-screen keyboard.
The text you add in this way becomes a part of the autoshape (when you move or rotate the shape, the text moves or rotates with it).
You can apply the same text formatting options as the ones for regular text. To edit the added text within the autoshape,
- select the text: double tap a piece of text within the shape and drag the selection handles,
- open the shape/text settings panel by
- tapping the
icon at the top toolbar, or - tapping the More option in the pop-up menu and choosing the Edit menu item,
- tapping the
- on the Text tab, adjust the necessary text parameters:
- change the font type, size, color,
- apply font decoration styles,
- apply the necessary horizontal/vertical alignment type,
- change text indents,
- create bulleted and numbered lists,
- adjust line spacing.
- on the Paragraph tab, adjust the necessary parameters for the multi-line text within the text box:
- change the paragraph background color,
- set the amount of space between paragraphs,
- apply paragraph styles,
- use the
Back icon on the left to return to the previous settings section.
Remove the shape
Select the shape by tapping on it and proceed in one of the following ways:
- tap the Delete option in the pop-up menu, or
- open the shape settings panel by tapping the
icon at the top toolbar, swipe up and tap the Remove shape button.
