Create lists
To create a list in your document,
- place the cursor to the position where a list will be started (this can be a new line or the already entered text),
- open the text and paragraph settings panel by
- tapping the
icon at the top toolbar, or - tapping the Edit option in the pop-up menu,
- tapping the
- on the Text tab, swipe up to see all the settings,
- select the list type you would like to start:
- tap the Bullets option to create an Unordered list with markers and select the marker type,
- tap the Numbers option to create an Ordered list with digits or letters and select how the list is going to look like,
- now each time you press the Enter key at the end of the line, a new ordered or unordered list item will appear. To stop that, tap the
key and continue with the common text paragraph.
You can also change the text indentation in the lists using the Decrease Indent
, and Increase Indent
icons on the Text tab.
