- Mobile Apps
- iOS
- Mobile web editors
- Document Editor web version
- Apply formatting presets
To apply one of the available text formatting presets,
- place the cursor within the paragraph you need, or select several paragraphs you want to apply one of the formatting presets to,
- open the text and paragraph settings panel by
- tapping the
icon at the top toolbar, or - tapping the Edit option in the pop-up menu,
- tapping the
- switch to the Paragraph tab,
- select the preset you need from the PARAGRAPH STYLES list (swipe it up to see more styles).
The following formatting presets are available: normal, no spacing, heading 1-9, title, subtitle, quote, intense quote, list paragraph, footer, header, footnote text.
Creating new styles
- format a text passage as you need.
- tapping the
- tapping the
- in the PARAGRAPH STYLES list, tap the Create new text style option. Specify the necessary parameters:
- Enter the new style name in the Title field.
- Select the desired style for the subsequent paragraph from the Next paragraph style section. The Same as created new style option is selected by default.
- Tap the Done option.
The created style will be added to the style gallery.
