Add hyperlinks
Add a hyperlink
- place the cursor where you want the link to be added or select the text passage that will get clickable,
- choose the Add Link option in the pop-up menu or do the following:
- tap the
icon at the top toolbar to open the new object insertion panel, - switch to the
tab, - select the
Link option,
- tap the
- after that the Add Link screen will appear where you can specify the hyperlink parameters:
- Link - enter a URL in the format http://www.example.com.
- Display - enter a text that will get clickable and lead to the web address specified in the upper field.
Note: if you've selected a text passage before tapping the
icon, the Display field will be filled with the selected text fragment. - Screen Tip - enter a text that will become visible in a small pop-up window that provides a brief note or label pertaining to the hyperlink being pointed to.
- tap the Insert button.
Note: to follow the added link, double-tap it and choose the Open Link option in the pop-up menu.
Edit or remove the added hyperlink
- select the link and open the text and paragraph settings panel by
- tapping the
icon at the top toolbar, or - tapping the Edit option in the pop-up menu,
- tapping the
- switch to the Hyperlink tab and perform the actions you need:
- edit your data and tap the Edit link button to save the changes.
- use the Remove link button to delete the added hyperlink.
