Change column width
Select the column you want to resize. The
handle will appear at the right border of the column heading. Tap and drag it to the left to make the column narrower or to the right to make it wider.
Change row height
Select the row you want to resize. The
handle will appear at the bottom border of the row heading. Tap and drag it up to shrink the row or down to expand it.
