Merging cells
Merge cells
You can merge two or more adjacent cells into one. Select two cells or a range of cells and tap the Merge option in the pop-up menu that appears.
Merge cell panel
Only the data in the upper-left cell of the selected range will remain in the merged cell. Data in other cells of the selected range will be deleted.
The cells of the selected range will be merged and the data will be aligned by the left side (for text) or by the right side (for numeric values).
Unmerge cells
To unmerge a previously merged cell, tap it and tap the Unmerge option in the pop-up menu. The data will be displayed in the upper-left cell.
