- Mobile Apps
- iOS
- Documents
- Spreadsheet Editor
- Selecting cell background color
Select cell background color
To apply a background color to a cell or cell range or change the current one:
- Select a cell, a range of cells, or the whole worksheet.
- Open the Cell settings panel by
- tapping the
icon at the top or bottom toolbar, or - tapping the Cell option in the pop-up menu.
- tapping the
- Tap the
arrow to the right of the
Fill color section to open the color palette panel. - Select the necessary color on the Theme colors or Standard colors palette, or create your own Custom color.
- Tap the
icon in the Custom colors section. - Using the color palette, choose the necessary color and select its hue level.
- Tap OK to apply the color to the selected cell. The added color will also be placed in the Custom colors section, where the recently used custom colors are located.
- Tap the
To clear the background color of a cell, use the
No filling option below the color palettes.
