- Mobile Apps
- iOS
- Documents
- Spreadsheet Editor
- Applying cell style
Applying cell style
Apply cell style
You can apply one of the predefined formatting presets to a selected cell:
- Select a cell, a range of cells, or the whole worksheet.
- Open the Cell settings panel by
- tapping the
icon at the top or bottom toolbar, or - tapping the Cell option in the pop-up menu.
- tapping the
- Tap the Cell styles menu item.
- Swipe up to see the Cell styles palette, swipe right or left to browse all the palettes, and tap the style you want to apply.
- Return to the previous screen by tapping the
arrow on the left and close the cell settings panel by tapping the
icon.
