- Mobile Apps
- iOS
- Documents
- Document Editor
- Selecting background color for a paragraph
Select background color for a paragraph
Background color is applied to the whole paragraph and completely fills all the paragraph space from the left page margin to the right page margin.
To apply a background color to a certain paragraph or change the current one:
- Put the cursor within the paragraph you need, or select several paragraphs or the whole text.
- Open the Paragraph Settings panel by
- tapping the
icon at the top toolbar and switching to the Paragraph tab, or - tapping the Paragraph option in the pop-up menu.
- tapping the
- Tap the arrow next to the color field in the Background section to open the color palette window.
- Select one of the available colors on the Theme colors or Standard colors palette, or create your own Custom color by tapping the
button.
To clear the background color of a certain paragraph, use the
No filling icon below the color palettes.
