- Mobile Apps
- iOS
- Documents
- Document Editor
- Inserting page numbers
Insert page numbers
- Tap the
icon at the top toolbar to open the new object insertion panel. - Switch to the Other tab.
- Select the
Page Number option. - Specify the page number position on the page: Top Left, Top Center, Top Right, Bottom Left, Bottom Center, Bottom Right, Current Position.
Adjust page number settings
- Tap the inserted page number to select it.
Open the settings panel by
- tapping the
icon at the top toolbar and go to the Header tab, or - tapping the Header option in the pop-up menu, or
- double-tapping the header or footer area directly on the document page.
- tapping the
Position — set the position of page numbers on the page relative to the top and bottom of the page. Use the
or
icons to adjust the position manually.
- Different first page — enable this option to apply a different page number to the very first page, or if you don't want to add any number to it at all.
- Different odd and even pages — enable this option to insert different page numbers for odd and even pages.
- Link to Previous — the option is available in case you've previously added sections into your document. If not, it will be grayed out. Moreover, this option is also unavailable for the very first section (i.e. when a header or footer that belongs to the first section is selected). By default, this box is enabled, so that unified numbering is applied to all the sections.
- NUMBER POSITION: TOP OF PAGE — adjust the positioning for page numbers at the top of the page. The following options are available: Top Left, Top Center, Top Right.
- NUMBER POSITION: BOTTOM OF PAGE — adjust the positioning for page numbers at the bottom of the page. The following options are available: Bottom Left, Bottom Center, Bottom Right.
- Current Position — insert a page number at the current cursor position.
Page Numbering — set the parameters for page numbering:
- Proceed — selected by default; keeps continuous page numbering after a section break.
- Start at — start page numbering with a specific number in the current section of the document.
- To delete page numbers, select a page number on the page and either use the Delete option in the pop-up menu, or delete it manually.
