- Mobile Apps
- iOS
- Documents
- Document Editor
- Inserting footnotes and endnotes
Insert a footnote or an endnote
You can add footnotes and endnotes to provide explanations or comments for certain sentences or terms used in your text, or make references to the sources.
- Position the insertion point at the end of the text passage you want to add a footnote or endnote to.
- Tap the
icon at the top toolbar to open the new object insertion panel. - Switch to the Other tab.
- Select the required option:
Footnote or
Endnote.
The note mark (i.e. the superscript character that indicates a footnote or endnote) appears in the document text, and the insertion point moves to the bottom of the page (for footnotes) or the end of the document (for endnotes).
- Type in the note text.
Repeat the above mentioned operations to add subsequent notes for other text passages in the document. The notes are numbered automatically.
Adjust the notes settings
- Open the settings panel by tapping the
button at the top right corner. - Tap the
Notes Settings menu item. - Choose whether you want to adjust Footnotes or Endnotes.
For Footnotes, the following parameters are available:
- LOCATION — sets the positioning of footnotes on the page: at the bottom of the page or under the text.
FORMAT — sets the formatting rules for footnotes:
- Numbering format — select the necessary number format from the available presets: 1, 2, 3,..., a, b, c,..., A, B, C,..., i, ii, iii,..., I, II, III,...
- Start with — use the
or
icons to set the number or letter you want to start numbering with. - Numbering — select a way to number your footnotes: Continuous to number footnotes sequentially throughout the document, In each section to restart numbering at the beginning of each section, or On each page to restart numbering at the beginning of each page.
- Convert footnotes — choose whether to convert footnotes to endnotes or swap the footnotes (regular footnotes become endnotes, and endnotes become regular footnotes).
- Remove all footnotes — tap this option to remove all footnotes altogether.
For Endnotes, the following parameters are available:
- LOCATION — sets the positioning of endnotes: at the end of the section or at the end of the document.
FORMAT — sets the formatting rules for endnotes:
or
icons to set the number or letter you want to start numbering with. - Numbering — select a way to number your endnotes: Continuous to number endnotes sequentially throughout the document, In each section to restart numbering at the beginning of each section, or On each page to restart numbering at the beginning of each page.
- Convert footnotes — choose whether to convert endnotes to plain footnotes or swap the footnotes (regular footnotes become endnotes, and endnotes become regular footnotes).
- Remove all endnotes — tap this option to remove all endnotes altogether.
Remove a note
To remove a single footnote or endnote, position the insertion point directly before the note mark in the document text and tap Delete. The remaining notes will be renumbered automatically.
To remove all footnotes or endnotes, use the Remove all footnotes or Remove all endnotes option in the Notes Settings panel as described above.
